Interrupt based Pulse Counter
Example Arduino sketch for interrupt based pulse counting:
//Number of pulses, used to measure energy.
long pulseCount = 0;
//Used to measure power.
unsigned long pulseTime,lastTime;
//power and energy
double power, elapsedkWh;
//Number of pulses per wh - found or set on the meter.
int ppwh = 1; //1000 pulses/kwh = 1 pulse per wh
void setup()
    Serial.begin(115200);
    // KWH interrupt attached to IRQ 1 = pin3
    attachInterrupt(1, onPulse, FALLING);
void loop()
// The interrupt routine
void onPulse()
    //used to measure time between pulses.
    lastTime = pulseTime;
    pulseTime = micros();
    //pulseCounter
    pulseCount++;
    //Calculate power
    power = (3600000000.0 / (pulseTime - lastTime))/ppwh;
    //Find kwh elapsed
    elapsedkWh = (1.0*pulseCount/(ppwh*1000)); //multiply by 1000 to convert pulses per wh to kwh
    //Print the values.
    Serial.print(power,4);
    Serial.print(" ");
    Serial.println(elapsedkWh,3);
Accuracy
Range of 0 to 25kW (typical range for solid state pulse output meters):
1000 pulses per kWh
Pulse Gen (kW) Pulse Counter (kW) Error (W) % Error Std. Deviation
0.101 0.101 0.00 0.00% 0
2.56 2.5599 0.10 0.00% 0.00017
3.15 3.1496 0.40 0.00% 0.00049
6.89 6.888 2.00 0.00% 0.001
9.56 9.556 4.00 0.00% 0.0019
10.63 10.625 5.00 0.00% 0.0024
19.62 19.6 20.00 0.00% 0.008
22.56 22.535 25.00 0.00% 0.0111
24.98 24.95 30.00 0.00% 0.0126
Notes
If the Serial monitor displays values rapidly, and at excessive power levels, try connecting a 10k pull down resistor to the digital input.
In this Chapter:
Learn
OpenEnergyMonitor
Copied to Clipboard
