Global variables in EmonCMS
Global variables can be declared in new modules, for example:
global $mysqli, $session;
There are many globals available, here we describe the more relevant ones.
$mysqli
Object that connects to EmonCMS database. It is an instance of the php class mysqli. You can see how to use it the php documentation: http://php.net/manual/en/class.mysqli.php
$redis
Redis is an in-memory database (MySQL is in-disk). $redis is used to reduce the write load to the database. Anybody how can do this section??
$route
Object that is an instance of the class Route. This class is defined in route.php Once the URL is decoded in index.php the $route object properties are set. For the following URL:
http://server/controller/action.subaction.format?attribute=blabla
The $route properties are:
$route->controller = controller
$route->action = action
$route-> subaction = subaction
$route-> format = format
$session
Associative array that stores info about permissions after a user or a node has authenticated. $session['userid']: the session has been started by this user or a node that belongs to him/her
$user
Object that is an instance of the class User. This class is defined in Modules/user/user_model.php This global variable is useful if you need to deal with: user login, user authentication, set/get user info like username, id, apikeys, email, language or timezone.
To know everything you can do using its methods, have look at the model.
In this Chapter:
Learn
OpenEnergyMonitor
Copied to Clipboard
